Time to open up a big can o' worms.
Back when I was learning how to design a suspension for pavement surfaces, I read Fred Puhn's book "How to make your car handle". It completely demystified the topic for me. Here's what I got out of it:
1. Do whatever you need to in order to heat up the entire cross-sectional area of the tire consistently (ie camber, tire pressures)
2. Weight transfer split front-to-rear should be changed with springs to affect balance. (This is also sometimes called LLTD or Lateral Load Transfer Distribution) The reason this works is because of the nonlinear coefficient of friction of the tires -- Lateral force vs Normal force is NOT a straight line and lateral force falls off with increasing normal force. So increasing weight transfer at one end decreases grip at that end and *increases* grip at the other.
So far so good -- all the above is for steady-state cornering. Shocks are a different story since they should only affect transitions. Just extrapolate #2 and imagine the shock doing the work of the spring in load transfer during transitions. This understanding has served me very well for almost 10 years of competitive driving on paved surfaces.
Now on to dirt.
Most of the underlying assumptions are no longer true. Tires don't heat up due to constant slip angle with a flat surface. Shocks are almost always in transitional state but the springs may still be steady state. Is the grip curve the same as tarmac tires? Does lateral force fall off as normal force is increased? Or could it actually increase due to the "digging in" factor? Also, what is the optimal slip angle for lateral force?
Among some of the rally suspension tuning "advice" I have heard:
1. You want shocks with really stiff compression damping
2. Stay away from shocks with really stiff compression damping
3. Stiffening swaybars will behave just like on pavement - stiffen the end you want to slide more
4. Stiffening swaybars behaves exactly opposite as on pavement
5. It's best to run with no swaybars
6. Stiffen springs on the end that you want to slide more
7. Stiffen springs on the end that you want to slide less
No one is in agreement on anything it seems. Any reputable sources of information?
Discuss
