Actually, before I get my revenge in the loop, let’s take a quick peek at the 2 sectors before it, 4 and 5. 4 was perhaps the least exciting part of the analysis as the time made through the slight chicane there was largely determined by the speed you carried into it off the back section. Either there really wasn’t enough of a feature there to upset the car much or Carl and I handled it consistently well each run. Of course, I lean towards the latter…
If anybody is reading along who wasn’t there, the sweeper in sector 5 fed straight into an optional 2-cone slalom. OK, it wasn’t much of a slalom but you had to pick which way you wanted to go at the first cone. With the exception of Carl’s 3rd run , we went to the outside of the first cone every time. Carl went to the inside on his third run and the sector times clearly shows that he was fastest through there on that run. So, should we automatically deduce that the inside was the way to go through there? Not so fast!
Close up look at the sweeper, sector 5:
Here again the GPS did a great job of distinguishing between Carl’s red inside line and my black outside line. Notice how the “sweeper” blue marker is defined very close to where our paths cross. This should be very close to the mid-point of the 2 cones that made up the mini-optional slalom. OK, so how did Carl’s inside line gain ~1/10th of a second on my outside line? This time, the answer is a little more subtle than it initially appears.
Speed -vs- time graph for sector 5:
One thing is clear, Carl absolutely kicked my butt coming out of the previous section! We’ve already established that nothing interesting happened in sector 4 so his extra speed is solely based on being smoother coming off the back section. We both got on the gas way back there at the same time but he managed to keep the car going the proper direction longer during that period. Like I said, he flat out-drove me through the entire back section.
Look what happens next, however. At ~1.8 second mark, our speeds are roughly the same. Where did that occur? It happens a good bit before our paths start to diverge. Carl had to bleed off a bunch of speed to get the car pointed towards the inside while I was still building speed I was missing from the previous section. Our speeds cross again as Carl and I hit roughly the same steady state speed which we then hold throughout the rest of our respective lines through the sweeper.
If you look at the circles representing the car in the previous image of sector 5, you’ll see that I’m pulling a lot more lateral g’s than Carl while he is busy accelerating forward. That point directly corresponds to the point selected in the speed graph at the 3.6 second mark. In order to fully illustrate the section from where our speeds first cross to where they cross again (~1.8 seconds to ~3.6 seconds), I created the following image. This was done by simply highlighting the section on the speed graph which shows some of the power of the software. It’s still clunky though!
Highlight of ~1.8 to ~3.6 seconds from the speed graph:
OK, let’s start from the beginning of this section again. We know that Carl came blazing in but if you look at the speed graph, sometime *before* the above highlighted section he had to turn the car to make the inside line. He starts turning around the .9 second mark and spends the next roughly 2 seconds bleeding off enough speed to make the turn. Meanwhile, I’m taking the longer outside line but I don’t have to slow down yet due to the fact that I can carry a touch more speed out there.
Now imagine if Carl had taken the outside line on that run. I believe his speed graph would keep climbing until roughly the 3 second mark at which time he would have had to bleed off very little to make the outside line. By rough calculations, I’m guessing that would have netted about an extra 2 to 3 tenths that neither of us found that day. Does that mean that it is always faster to go ‘round the outside? Nope! But I think on that course during that period of time, the outside was a little quicker.
While it is a little hard to see from the speed graph above, we can also learn something from the tail end of the sector. The graph along with the other data shows that I got off the gas a touch sooner than Carl but we wound up getting on the brakes at roughly the same time. That means I coasted for a bit before applying the brake while Carl jumped right on them. This could be the difference between a left-foot braker’s possible quicker reaction time (Carl) -vs- a right-foot braker (Me) or it could be that I was just coasting. I tend to lean towards the “coasting” theory at the moment as I do remember trying to be extra gentle with my inputs.
No matter what happened, the end result was that Carl was carrying a bit more speed right at the end of that section but as you will soon see, sometimes you have to go slow…
