I couldn't load the files with XP's Movie Maker (improper codec but it sure gave an obscure error message) so I found another program, VirtualDubMod, which let me open and play with the files on the PeeCee.
That's right! VDubMod in 'da house, representing Deutschland!
Anyway, I trimmed both files to the point that the car first starts moving so they start at essentially the same place. If your software can seek by frame number, my car starts moving at frame 594 in CHN_0012.MPG while your car starts moving at frame 552 in CHN_0013.MPG. Well, they are both your car but you get the idea.
After that, I played each movie and tried to stop near the areas you were talking about with a decent reference point in each frame. Notice that I stopped the movies at exactly the same frame number each time so it should be as accurate as it can be. The images are a little big so I'm going to just post a link to them.
Jim heading into sector 3
Carl heading into sector 3
If you use the (fuzzy!) cone at the right side of the pictures as a reference, it looks like we are in a dead-heat at that point.
Jim leaving the loop
Carl leaving the loop
If you use the cones at the left side of the pictures as a reference, it appears you have a *slight* lead on me at that point. After seeing that, I went back to the data and put a new marker at roughly that point on the course. According to the data, I ran a 50.14 while you ran 50.01 up to that point so it looks to be spot-on to me.
Jim crossing the finish
Carl crossing the finish
For this final pair of images, I didn't pick the same frame number since you got there first. Instead, I tried to match up where we both crossed the finish line by using the finish cone on the left side of the pictures. If you look at the time stamps at the bottom of the pictures, you'll notice that your time is ~63.7 (1:03.664) seconds while mine is ~64 (1:04.031) seconds. That matches up very well with our posted times as well as the data.
For those that don't remember, keep in mind our times are longer here in the "virtual world" because we are using a different start and finish line. As I said before, it's the start that has the biggest impact on the discrepancy. According to the video, it takes ~3.7 seconds just to trip the start beam! So if we take Carl's real world time (ignoring the cone) from his 3rd run and add 3.7 seconds, what do we get? 59.985 + 3.7 = 63.685 seconds. That is very close to his "video time" of 63.7 seconds and matches up nicely with everything else.
I'd be inclined to say that the video didn't drop any frames and looks to be right as expected. I'm not sure what happened with your video but I did notice that it is very easy to be off by a few frames. Considering each frame is ~0.033 seconds, it can start to add up quickly.
I'm hoping to sync the data with the video and have some overlays in the next few days but it is low on the priority list at the moment.
Just for grins, I took a screen shot of where I would be on course when Carl just crossed the finish line. He was ~0.3 seconds ahead at the time and if you ever wondered what that looked like at roughly 35mph, here it is:
Carl is in the pits having a cold one while I'm still charging towards the finish.
