Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Thu May 11, 2006 4:43 pm
SUPER Post Whore
Brian Herring wrote:
- SR,SF,SA -- Rally Stock (basically, completely stock)
So can you replace shocks in the Rally Stock class?
Jesus Ryan! RTFL!
http://scca.com/Rally/Index.asp?IdS=000 ... 040|070&~=
Sorry, had to be done. :)
So, to answer your question -- in stock class, NO, you can not replace the shocks with anything other than OEM replacements. Hence why I am in Rally Prepared.
- dow
PostPosted: Thu May 11, 2006 6:12 pm
- dow
And because you have a WRX rear sway bar.
2010 Honda Fit Sport
Couple of bicycles
PostPosted: Thu May 11, 2006 6:49 pm
Jesus Ryan! RTFL!
- dow
Ok, I earned that...
So wow, OEM replacements ONLY. No Koni yellows, no nothin'
Hmmmmm, damnit, I had about talked myself OUT of that Legacy.
PostPosted: Thu May 11, 2006 10:16 pm
Unless Koni Yellows are the OEM part on your car... :wink:
Carl
1996 Dodge Neon ACR
270k miles
PostPosted: Thu May 11, 2006 11:17 pm
SUPER Post Whore
- dow
Don't forget the red center console. That throws me straight out as that thing is NO WHERE near stock ;)
I think the lleft side tranny cross member mount does as well :)
- dow
PostPosted: Tue May 16, 2006 8:29 am
ok so this may be a stupid question, but evidently i am not the brightest bulb as i do not own a scoobie, is The General eligible to run in this event? provided i can convince my co owners i might be interested in this.
PostPosted: Tue May 16, 2006 9:35 am
There is no reason it wouldn't be eligible to run as long as you can get it to the event.
Couple of bicycles
PostPosted: Tue May 16, 2006 9:42 am
So w/o being a smart a**, do you think we would be competative? I still wouldn't mind going though.
PostPosted: Tue May 16, 2006 10:26 am
my question also Vincent. but it would probably be a blast anyway.
PostPosted: Tue May 16, 2006 11:32 am
You would be running in RPF. Which is rally prepared front wheel drive. I assume that is where you would fit in atleast. That is a rally tire class. So you take it from there if you think you will be competitive. I wasn't trying to be a smarta** just for the record.
Couple of bicycles
PostPosted: Tue May 16, 2006 11:57 am
SUPER Post Whore
Um, the CAR isn't competitively classed. With a gutted interior and no cats, the car is in RP. Due to the classing structure, you would need rally tires to have a good chance, IIRC what Kevin has told me about the surface there.
However, that isn't to say that you can't go with the car, and show other people up in a beater.... that is smoking... and place well. This is a 'National', and at Oakland Acres, so I think 'winning' is going to be a hard sell for any car, IMHO.
My vote is to take it and have fun. That is what I am doing as I know a I am going to get smoked. Regardless, this is a chance for the car to come back with some more stickers on it :)
- dow
PostPosted: Tue May 16, 2006 12:14 pm
Steve, if you don't mind hauling the General up there, then there is no reason why you can't and shouldn't run. As Keith and Brian said, the classing is more or less going to be the deciding factor as to how you may place. It's a scary/fun course regardless. So if you go to have a good time, then you won't be disappointed.
Vincent, as far as the competative part, same thing applies. The General is definitely a hoot to drive and can be taken to the top, but with the SCCA classes and the people who will be in the class that the General is in, you will have your hands full trying to stay on top. Not saying it can't be done, but it won't be an easy task.
If you go, great. If not, well you can figure that out. :wink: :twisted:
PostPosted: Tue May 16, 2006 3:44 pm
next question. will The General pass tech?
i am in this for shitz & giggles, if i was worried about winning i would have quit a long, long time ago.
PostPosted: Tue May 16, 2006 4:14 pm
http://www.scca.org/_filelibrary/File/2 ... srules.pdf
Ref Section 3.3.
Carl Fisher
Be Cool to the Pizza Dude:
PostPosted: Tue May 16, 2006 4:18 pm
Ref Section 3.3.
all day long. thanks Carl
