Is there precedent for a rule like this?
If it is a common national rule, I might support it.
FIA: Article 252 General prescriptions for rally cars. From article 7:
7.4 All body panels of the vehicle must be at all times of the same material as those of the original homologated car and must be of the same material thickness as that of the original homologated car (tolerance ± 10 %).
7.6 Any object of a dangerous nature (inflammable products, etc.) must be carried outside the cockpit.
SCCA Rally Rulebook:
3.4.A.3 GENERAL APPEARANCE
All vehicles (entrant, support) at any ProRally Parc Expose
must be clean and neat in appearance.
6.4. MINIMUM SCRUTINEERING REQUIREMENTS
A.12:
12. Hoods must be fixed closed with hood pins accessible from theoutside. Other fastening devices (inside or outside) must be rendered inoperative except for the secondary catch.
CLASS DEFINITION:
10.2.B.5 Bodywork:
a. Exterior panels, except for allowed flares, must be
visually similar to the original components, including
bumpers. Except for doors, bolt-on body pieces may
be constructed of an alternate material. Roof
mounted, commercially available cooling vents are
allowed. Any significant deviations from road-going
components available from the manufacturer of that vehicle
must be approved in advance by the PRB.
For Prduction classes, 24.o:
p. The rear seat, headliner, and trim pieces from the "B" pillar rearward may be removed. All door panels may be
modified for clearance of the roll cage, but all OEM door
panels shall be retained.
25: Coach Work
Carpets and their associated padding may be removed. The
front seats shall be replaced with seating per Article 5.
Standard seat/shoulder belts may be removed. The glove boxdoor may be removed or replaced. Passive restraints, including air bags, shall be removed or disabled.
Canadian Rules:
D General Regulations
1. Bodywork.
(a) Bodywork must be without visible damage or perforation from corrosion which would detract from the good appearance of the vehicle.
NASA Rally rules
3.1.3 Vehicle Eligibility
Vehicles eligible for events must be production based four wheeled passenger vehicles generally available for purchase by the general public. "One-of" vehicles specially built from the ground up for competition use is prohibited. To this end, the frame, floor pan, basic body shell, and firewall must remain original but may be modified for strength or to accommodate legal components. Exterior panels, including fenders, engine hood and trunk lid of hatchback must be present and visually similar to the original components.
3.2.3.3 Authorized Modifications
b. Exterior pieces (i.e.: all components licked by the air stream) must be visually similar to the original item, including bumpers.
So,
for rally, it's pretty clear you can't remove exterior body panels, hoods, or trunks. Interior stripping is generally allowed in open class cars, but not completely in Production based cars, with some variations. So I'd say there's a fairly worldwide consensus within the rally community on those issues, along the lines Carl is going.
Anders[/i]
