Carl - please separate this into 2 separate rule discussions:
1: Cars maintaining a stock external appearance (benefit - the series)
2: Reducing the potential for occupant injury (benefit - occupant saftety)
There already
are two discussions here.
This one is about safety, the other one (Running Stripped And Gutted Cars or whatever) is about appearance. I am separating the discussions by issue (safety vs appearance), you are separating them by location (interior vs exterior). I see merit to your division, but also to mine. Let's talk about appearance issues in the other thread.
Now is there really some external panel modification SAFETY risk like you implied in your original post? I don't get it.
Sharp edges are a hazard anywhere, inside or outside, aren't they? If I cut my fenders and leave sharp edges pointing out, that's a hazard. If I cut my fenders and roll the edges under, it's not. Removing a trunk lid, for example, is not likely to expose any sharp edges. Removing a hood or fenders might, depending on the car. Even if sharp edges
were exposed on the vehicle exterior, they should not be too hard to fix, as has been noted earlier.
Now
I don't understand what "let tech handle it instead of a rule" means. If tech finds a loose battery or a bad tie rod and the car can't be made safe in time to compete, then it won't be allowed to run, right? In effect, there is a rule that batteries must be secure and steering and brakes must pass a cursory inspection. I see that our rules don't mention them, though. Would you object to having those tech items added to the rules? If so, why? If not, then what's the issue? Please explain.
Carl Fisher
Be Cool to the Pizza Dude:
