OK folks, the track is all set. We just need to show up and have some fun. Wilson has gotten a little more rain than the triangle area and some areas were pretty muddy. I believe that we have navigated a course that will be fun and over 1-1/2 minutes to drive (even if you are Kevin).
I have got to get a new mechanic (i.e.: someone other than me). To test the course I let Ricky Beam, our bus driver for the weekend, drive the Sentra. He made a couple of passes then the front wheel fell off. During my fighting with the steering arm repair and alignment I had left the wheel lugs snug but easily removable for access. At some point I should have confirmed that the lugs were torqued... but I didn't. So as a cautionary tale, check your nuts before you drive.
Come on down and have a grin Sunday.
If you are there early here's a laundry list of things that could use some TLC:
1. Timing cables from bus to start and finish
2. Use the timing cable Big Freaking Hammer and one of the big nails make holes in the rocky course to drop in the cone marker flags. We pushed them in a little by hand, but they really resisted.
3. Fire bottles, number markers, and flags delivered to the worker stations
4. Start and finish (green & checkered) condoms installed
5. Setup the registration table for sign-in and wrist bands
6. Take a serious walk of the course and decide where to brake early for a slow entry to the slippery spots (slow and controlled in, fast out). This may be a discipline building course for some, and simply hilarious for others.
Charlie Guthrie
