Charlie Guthrie wrote:
I'm surprised that no one has mentioned "pull-up" vs "pull-down" tightening for the lap belt. This makes a whole lot of difference depending on the seat and accessibility to the tighteners.
Charlie Guthrie
Actually I did back in post #4.
Pull down lap belt adjuster are near impossible with a console next to the seat unless you like the adjuster right on top your leg.
I like pull down shoulders and pull up lap. Donna and I would pop the harness and run the adjusters out on the way back to grid. It's much much easier to latch up if the belts are not tight when you start, then pull them snug. Start with the crotch strap(s), then the lap straps and finally the shoulder straps. In deference to popular belief, the crotch strap is NOT there to keep you from sliding out from under the harness, a very unlikely scenario unless you have the seat fully reclined, but to counter the shoulder straps from pulling the buckle up under your sternum in a crash which can cause massive internal injuries and even death from the harness rather than the accident. There is very specific harness mounting geometry that should be adhered to to also reduce the risk of additional belt injuries. Do some research online, but I think Simpson's site shows diagrams.
