 Post subject: Daily Driving and Lifespan of Koni Yellows?
PostPosted: Mon Apr 06, 2009 9:05 am
So I daily drive my 240. I currently have Koni Yellows with stock springs. The rears are not adjustable unless I remove the shock. Normally I drive around with the fronts on 1/8 stiff and when I get to the autocross I set them at 7/8 stiff. To me there is not a huge difference in feel with the settings, but noticeable. My question is, is there a setting that would be best for the longevity of the these shocks during daily driving? I've heard it is not a good idea to be dialed into full soft or full stiff, so that is why I back off a quarter turn. If it does not really matter, I'd prefer to just leave them at 7/8 stiff.
 Post subject: Re: Daily Driving and Lifespan of Koni Yellows?
PostPosted: Mon Apr 06, 2009 9:37 am
The whole "no full soft or full stiff" is urban legend. Lee Grimes of Koni NA has said it doesn't hurt the shock at all to be full soft/stiff and when you see the valving dyno curves, it shows both extremes.
As for longevity, the shocks are as good as the seals. If you see leaking, usually evident from a dirty drip mark on the shock body, then the shock needs to either be replaced or rebuilt. - AB
PostPosted: Mon Apr 06, 2009 10:42 am
While it might not hurt the damper itself, it can bork up the adjuster to leave it at the full adjustment. That's what the tech told me when I had one replaced under warranty on the Contour ...
PostPosted: Mon Apr 06, 2009 12:28 pm
I had yellows on my prelude for 2-3 years with ~30k miles on it. The seemed ok after that period. I ran them near the middle for the street. I would think if you DD them you should plan for a refresh-rebuild every few years if you want optimal performance though.
PostPosted: Mon Apr 06, 2009 12:48 pm
While I agree it's possible, I've run Konis on all of my autocross cars for the last 7 years (although the C6 is on Pfadt shocks) and I've gone full stiff and full soft on OTS singles/revalved singles/custom double adjustables and have never, ever, had an adjuster break or lock.
I could just be lucky :wink:
I do agree with Michael that a fresh rebuild every few years is good for optimal use. The problem with that is that OTS singles probably are just as expensive as a rebuild, so unless you have custom valving (or desire that for springs stiffer than 450# rates that most of their OTS singles can handle), buying new ones and unloading the old ones at a significant discount is the way to go. - AB
PostPosted: Mon Apr 06, 2009 1:16 pm
There is no probably about it, for the 240, its the same exact cost new vs rebuild per Lee Grimes at Koni.
PostPosted: Mon Apr 06, 2009 1:30 pm
Yeah, that is about what I remember as far as rebuild prices. It might be of interest to be able to adjust the rears on the car in the future, but since the rest of the suspension is stock I don't think I can get it too still the rears are at ~3/4 still.
I'll try running the fronts at full stiff at the next event.
PostPosted: Mon Apr 06, 2009 1:31 pm
I ran mine for 5+ years on my DD and I never had problems with the adjuster, but there were pretty much worn out and need of replacement (rebuild) when I finally pulled them off the car and went back to stock setup.
PostPosted: Mon Apr 06, 2009 2:09 pm
For most cars, yes, it's close if not the same. For other cars, a rebuild is much cheaper. For the C5 & C6 Corvettes, OTS Singles are around $1k. - AB
PostPosted: Mon Apr 06, 2009 9:12 pm
Hmm, maybe they're not doing this anymore, but I bought mine (SA yellows) for the Neon from GH Sharp (SF Motorsports) back in '97 or so, and they came with lifetime replacement guarantee. That was probably 250k ago- I'm sure I've replaced them all at least 4 times, all for the cost of return shipping for the junkers. Last time I did that was maybe 18 months ago?
Carl Fisher
Be Cool to the Pizza Dude:
PostPosted: Tue Apr 07, 2009 8:33 am
They do have a lifetime warranty, to the orginal seller. If your like me and bought them from 2nd hand that warranty does not apply.
David Teague
2015 Lexus IS 250c
1994 Honda Del Sol HS 39
2009 Dodge Journey R/T
http://teaguefamily.us
PostPosted: Tue Apr 07, 2009 3:37 pm
I actually replaced my front via this method. If I remember correctly if you didn't want to be without (such as for DD), they would see you replacements at pretty much what I think is their dealer price. Then you swap out new for old. Mail them back the old and if they agree there is a warentee issue, they will refund you what you paid for the new ones.
PostPosted: Tue Apr 07, 2009 7:19 pm
I hung out with Lee at the Koni trailer at Nationals last year. I learned a lot. Among other things, I learned that running them at full soft, or full stiff, is fine. Lee told me, "if we didn't want people to set them to those settings, we'd change the range of adjustment."
I'm familiar with the perception that running them full stiff is bad for them - I've heard of it before. Lee said it's not true.
