Rodney,
I would advise going with V710s over the A6 also simply from the longevity standpoint. The next step would be to use the BFG R1 which, according to the test GRM mag did, was very close to the A6 and V710; however, the R1s will last MUCH longer than either of the other two. The R1 is a great tire from a feedback standpoint whereas the A6 is initially fair but as it gets heated up it requires higher slip angles and is much more difficult to feel the top of the traction curve. You can run the R1 at VIR and have a blast on them. No chance of doing that for long on the A6.
There was a test recently on a skidpad where they simply kept doing laps and heated up the tires (A6s). Once the tires got above 160F, their grip plateaued but the hotter they got, the more slip angle you had to give them to get that max grip out of them. Hence they feel sloppy, imprecise, etc, once you get them really hot. You can feel this difference in our long autox courses as the tire is a completely different animal from the early part of the course to the latter part (at least on the 330i where they were getting serious heat in the fronts). Chris Peterson learned this first-hand in the Evo Extreme school too.
Hence you will need to keep them cool at our events with lots of spraying and such.
Conversely, the R1 loves heat. I rarely spray them. My experience on the 330i is that they lasted somewhere more than 7-8 times as long as the A6s did on that car (I could do in a new set of front A6s in less than 15 runs and at $274 each, it wasn't exactly fun). I finally did in a set at the extreme school last year after way over 120 runs on them.
So, yeah, with the R1 you won't have the "top of the line" autocross tire, but it is perhaps 95% there or so. They last, they're fun to drive on, you won't ever see someone at a national event trophy on them, but...oh yeah, they last.
