Ron Spencer wrote:
Kevin according to the traqmate manual (yes, worth reading!) the horsepower (and I'll assume torque) numbers are only valid when you are foot to the floor on a straight and level part of the track. All other numbers are suspect.
Using that my Honda shows a believable number of, if I recall correctly, 116hp. The torque numbers are still messed up. Off by a factor of 10 or more!
Ron
I don't need no stinkin' instructions!
Actually Ron, you're absolutely right. That's why I would only have faith in a Front Straight output (after thinking about it). But boy, big numbers sure can get you excited!
Power is the rate of change in Work, and Work = Force x Distance and Force = Mass x Acceleration. So the Traqmate power output is only as good as the weight you have entered for the car as well.
I have 2555 lbs entered as that is the total weight of myself in street cloths plus full, wet weight that the car measured on the scales at Roebling a couple of years ago.
