 Post subject: DIY Posi-traction
PostPosted: Sun Dec 21, 2008 6:54 pm
Keith and I want to lock the differential in our Sentra to have posi-traction.
It seems our options are the following
o Weld
o Fill the entire cavity with an epoxy
Any advice out on performing this?
Will a weld hold?
Epoxy sounds good but I suspect it might fail and if it does would trash the rest of the gears.
Any volunteers to help weld? We've already opened the case. We have the diff unit out.
"Ruttin' is racing"
Chris Suich
Apex, NC
FunX 1970 Camaro LT1 ('95)
 Post subject: Re: DIY Posi-traction
PostPosted: Sun Dec 21, 2008 7:43 pm
o Weld
Will a weld hold?
Welding it will work, but I've only seen it done in RWD cars. I'm not sure what issues you may have on throttle and steering at the same time. I can remember driving Scott Johnson's old Celica with a welded diff, and during slow speed stuff, you could feel it pulse. - AB
PostPosted: Sun Dec 21, 2008 9:07 pm
I have done welding on several round track dirt cars. Never had the weld break, but def interesting to push the car. I dont see y you would have any problems with it.
PostPosted: Sun Dec 21, 2008 10:13 pm
Welding will work but I expect it will plow like a dump truck and have a lot higher steering effort too.
You might want to consider shimming the spider gears so that they are really tight. This should give you some positraction effect too.
PostPosted: Sun Dec 21, 2008 11:23 pm
Back in the day some of the Dodge rally guys would weld up their (FWD) differentials. Made the car very difficult to turn, particularly at low speeds, but they would compensate by adding an inch or so of toe out at the rear. Not sure how it would work for rallyX, but hey, it'd be fun to watch!
Carl Fisher
Be Cool to the Pizza Dude:
PostPosted: Mon Dec 22, 2008 8:23 am
I'll be glad to help with the welding. FYI, I'll be in Apex this coming Sunday. If you can bring it to me I can do it then.
PostPosted: Mon Dec 22, 2008 11:00 am
I think it will be fine as long as you stay on dirt. It will be hard to turn at slow speeds, but you guys never go slow!
Rubbin' is Racin'
 Post subject: 1wd
PostPosted: Mon Dec 22, 2008 8:41 pm
the toyota is 1wd. believe me, you have not rallied.. until you run sloppy conditions, 71 whp. and 1wd... that is a riot, you spend the whole time thinking you are on black ice. :P although it sits up high enough if you pay attention and keep your foot in her, she has yet to get totally stuck. except for the one time at rockingham.. then she got high centered, not really stuck. but having a LSD on my sentra, i love it. i can see why you want a lsd-ish for your sentra.. if it is not really expensive, why not find a se-r in a junk yard, take the diff out and put it in your car. provided it still works that may be another route as well. 1991-1993-ish they had the diff still. afterwards they took it out. try city auto salvage in durham or nines wrecking yard too. try to find the diff out of a early se-r. put that on if it is not too expensive.
 Post subject: Re: 1wd
PostPosted: Mon Dec 22, 2008 11:03 pm
It's my understanding that the SE-R drivetrain is completely different. Like transmissions would not swap. I would not believe that the gears would be interchangeable.
"Ruttin' is racing"
Chris Suich
Apex, NC
PostPosted: Tue Dec 23, 2008 5:14 pm
welding will work fine- you only really need to jam the spider gears together, so just weld to your hearts content, just be careful to not get too much spatter on the ring + pinion gears.
 Post subject: Jam-a-Block!
PostPosted: Wed Dec 24, 2008 2:28 pm
How about the "Jam-a-Block" Phantom Grip? :)
http://www.phantomgrip.com/catalog/index.php?cPath=44&osCsid=c6b923338fd2ec5a606312314e30c6dc
Brad
 Post subject: Re: Jam-a-Block!
PostPosted: Wed Dec 24, 2008 6:42 pm
Brad Mackey wrote:
Welding is about $300 cheaper.
