Changing a front hub on my '93 Miata track car, so i figured it was a good opportunity to change out the wheel studs to extended-length studs all around. Ordered a complete kit from
http://advanced-autosports.com/technical.htm.
Comparing the OEM studs to the new aftermarket extended studs, the knurl under the head on the aftermarket studs is coarser than the OEM studs.
I'm hesitant to press in the new studs if Advanced Autosports sent me the wrong studs. Then again, maybe it's no big deal.
Knurl O.D. on the OEM's is .504" (12.80mm) vs. .512" (13.00mm) on the Aftermarket studs.
Is this a problem? Anybody run into a similar situation?
