 Post subject: bled brakes with mity vac hand vac pump? & other methods
PostPosted: Wed Jun 18, 2008 10:23 pm
Maybe you can help me. No matter how I open the bleeder screw, I the fluid will not flow in a constant manner. It seems more like a spit than a stream. I'm pumping about 25 in/hg of vac and slowly opening the screw. Its pulling very little fluid. Nothing like the steady stream when someone is there to pump.
Last edited by Matthew Fortner on Thu Jun 19, 2008 10:48 am, edited 3 times in total.
PostPosted: Wed Jun 18, 2008 11:25 pm
Motive Power Bleeder
/end thread :lol:
Seriously - I tried the MityVac exactly once, now I just use it to suck out the reservior before attaching the power bleeder.
PostPosted: Wed Jun 18, 2008 11:27 pm
You know I borrowed and tried one on our Jetta and it did not move the fluid well at all so I sort of gave up on it. Maybe though it would work better with the RX-8.
Last edited by Matthew Fortner on Thu Jun 19, 2008 12:09 am, edited 1 time in total.
PostPosted: Thu Jun 19, 2008 12:01 am
/end thread :lol:
Yes. Kendt speaks the truth.
PostPosted: Thu Jun 19, 2008 12:05 am
My MitiVac showed an amazing ability to suck air in around the bleed screw threads. No, applying grease to the threads did not help.
Bought a Motive Products power bleeder. It did not push fluid through nearly as fast as someone pumping the pedal (in fact, just a trickle at the rear brakes), but it did eventually clear the residual air out of the MC and the lines. 4 quarts of fluid and a 1/2 day of vacation... Only problem was when the adapter popped off the master cylinder and sprayed brake fluid around the engine compartment. I never knew I could mount 4 wheels and get the car off jack stands that fast. (Had to get it outside to wash out the brake fluid)
PostPosted: Thu Jun 19, 2008 12:14 am
That actually gets easier with practice Art. And here's another tip - test fit the adapter with an empty power bleeder before filling it with fluid. If you can hear air hissing out of it, you need to check your fittings.
PostPosted: Thu Jun 19, 2008 2:19 am
I've never needed to move 4qts of brake fluid through a car before to get it bled properly. I could see putting fluid in the Motive unit. For my bleeding purposes. I don't even put fluid in the Motive. If needed remove fluid from reservoir with big syringe. Fill to top. Attach Motive and pump to 15lbs. Start bleeding. After about 4ozs or so. Let pressure out of bleeder, remove from reservoir, add fluid. Pump up Motive again and finish.
I never have to deal with fluid in the Motive unit or making a big mess. It's just there for applying pressure. I get very good flow out of the bleeders with it.
The Mighty Vac I had the same problem with. Makes lots of air bubbles around the bleeder screw. Not much else...
PostPosted: Thu Jun 19, 2008 10:02 am
Ditto on Graham's method. I have done it both ways. While it might take a little longer than putting a bottle of fluid in the bleeder, it drastically reduces the chances for a big mess!
The mighty vac is like chasing your tail, go around and around and seldom have a good result.
 Post subject: Re: if you've bled brakes with a mity vac hand vac pump?
PostPosted: Thu Jun 19, 2008 10:09 am
I have gone back to the old pumping the pedal method. I have both the motive and the mighty vac.
The motive on the rectangular GM reservoir just will not seal properly for me. The mighty vac is a hit or miss. Currently, it works great on the right side caliper but will not seal on the left side. It is a temperamental POS.
PostPosted: Thu Jun 19, 2008 10:44 am
Pseudo cautious/nervous guy
I use the "dry power bleeder" method that Graham describes. I use a home-built bleeder (thanks VK) with a Motive cap, and it works great. I will deal with the annoyance of having to disconnect the cap and refill the reservoir over spilling brake fluid everywhere.
Tom Freeman
Team Silver Bullets '91 240SX
PostPosted: Thu Jun 19, 2008 10:46 am
I don't mind giving up on the Mity Vac since I got in for vacuum and pressure solenoid testing anyway. I had used Speedbleeders on my RX-7 with great luck, but I've heard some scary stories since and I'm less enthusiastic about using them on the RX-8.
PostPosted: Thu Jun 19, 2008 12:32 pm
What scary stories?
Thanks
PostPosted: Thu Jun 19, 2008 1:26 pm
DickRasmussen wrote:
What scary stories?
Thanks
Various tales of leakage and failure on the internets. FWIW. I never had any issues. I loved them, but I'm very much about not introducing more possible failure points.
PostPosted: Thu Jun 19, 2008 1:27 pm
I may pick up a used Motive bleeder. If anyone here has one they want to sell with a cap that will work on the RX-8....lemeno.
PostPosted: Thu Jun 19, 2008 1:34 pm
What scary stories?
Thanks
I had one break when I was bleeding the driver's front in the Miata. I shipped the caliper back to Speedbleeder, they got the old one out and replaced with a new one. :shrug:
