 Post subject: Miata Timing...
PostPosted: Mon May 05, 2008 9:54 pm
Anyone have a timing light?
I had to replace the crank angle seal this evening. I marked it with a pencil and did my best to align everything back up, the car runs fine but I figured it would be a good idea to check the timing anyways just to be safe since I have read the Miata is pretty finicky on even small changes in timing.
From reading on Miata.net it sounds like 12* BTDC is the magic number.
I can supply a cold 12 pack for some help :D
91 Miata STT #28
PostPosted: Tue May 06, 2008 9:49 am
i've got one with me here in greenville. are you going to the nceuro meet? if i make it to the meet tonight i'll bring it for you. if not it looks like i'll be in religh at some point this weekend.
#77 nasa spec 3
e36 M3
PostPosted: Tue May 06, 2008 12:16 pm
I probably wont make it out to the meet tonight, is my work kickball leauge lol
I'll let you know if I dont find one
91 Miata STT #28
PostPosted: Tue May 06, 2008 1:23 pm
Aww, what a cute little car!
good luck with that...from what i remember, using a timing light with a miata is a PITA. maybe the 1.6 is different though.
05 MCS
PostPosted: Tue May 06, 2008 1:43 pm
It takes less than five minutes, and that includes finding your tools.
PostPosted: Tue May 06, 2008 2:34 pm
I've got one. It's near NC-54 and NC-55. You are welcome to play with it.
PostPosted: Tue May 06, 2008 2:38 pm
hahaha...that shows you how good my memory is...i thought it was you that said it was a pain...somthing about getting the timing gun in a position that you could actually see anything...oh well, i guess i'm crazy
05 MCS
PostPosted: Tue May 06, 2008 4:07 pm
The PITA is getting at the crank position sensor nuts/bolts.... other than that it's pretty simple.
PostPosted: Tue May 06, 2008 6:59 pm
I swapped out the CAS O ring after work yesterday, took about 30 minutes or so. I nicely angled 12mm fits right in there :D
91 Miata STT #28
PostPosted: Tue May 06, 2008 9:26 pm
Oh sure.... think you're so kool 'cus you've got the right tool for the job. That's not how real mechanics do it.
PostPosted: Sun May 11, 2008 6:48 pm
haha - I got the timing set to 12* BTDC and the car runs much better, it was at 10*
91 Miata STT #28
