 Post subject: Trailer Box
PostPosted: Thu Feb 14, 2008 4:41 pm
Captain Caution !
OK, this may be a lengthy post but I'm looking for some advice.
First some background...
I have a trailer (it used to belong to Matt Nicholson) that used to have a truck box mounted in the front. I had to remove it when I mounted a weight distribution hitch (tows _so_ much better now) because the box interfered with the WDH brackets. We're kinda making do without the box but it was quite useful.
I now find that we need to tote some fuel jugs to our events (so I can blend to a higher octane) and I have 3 VP Racing jugs that are 10x10x22.5 inches. I don't want to carry them in the tow vehicle and it's a pain to get them secured in the rally car (we're already carrying a ton of stuff in there when it's on the trailer). So was thinking they could be mounted on the trailer tongue somehow.
Things I've considered...
1. Build a three pocket "basket" from PVC tubing and secure it to the tongue. Has the advantage that it's within my fabrication skills and cheap.
2. Build a wooden cage from 2x2's with plywood floor and mount to tongue. Still within my skill level but probably prone to rot and failure from water damage.
3. Buy a trailer tongue box. None of the ones I've seen are quite tall enough to accommodate the jugs. I need an interior height of 22.5 inches. Plus they're several hundred dollars. Also, I'm not sure if they're narrower than the truck box I had to remove.
4. Have some fabricate a box or cage out of metal (welding?). Outside my skill level but possibly cheaper than a pre-made tongue box.
Your suggestions are solicited and welcome.
Thanks.
Simon
< http://usukracing.com >
PostPosted: Thu Feb 14, 2008 4:59 pm
How much room between the front of the car and the front of the trailer? Enough room to mount this?The one I have in my trailer is aluminum, holds two jugs and has a back. Probably around $90 or so.
PostPosted: Thu Feb 14, 2008 5:02 pm
Milk crates bolted to 3/4" plywood bolted to the tongue w/ U-brackets. Bungees to hold the fuel jugs in.
Ghetto but easy and effective.
PostPosted: Thu Feb 14, 2008 5:36 pm
Captain Caution !
The trailer has a convenient wheel bar that goes across the front, prohibiting the use of that space (not that there's much of it).
Good suggestion though, thanks.
PostPosted: Thu Feb 14, 2008 5:37 pm
Captain Caution !
Hmmm. This has possibilities.
Simon
PostPosted: Thu Feb 14, 2008 6:53 pm
saferacer.com has something similar to Jim's suggestion but cheaper. i have one and it is currently priced @ $58. does your trailer have running boards Simon?
fuel jugs on the tongue add to tongue weight. stating the obvious but still......
PostPosted: Thu Feb 14, 2008 7:01 pm
jugs on the tongue add to tongue weight. .....
Ok, I have had a couple of beers, but I think this is funny, I don't care who you are :lol:
PostPosted: Thu Feb 14, 2008 7:03 pm
Are you looking for reruns of the man show on You Tube? :D
PostPosted: Thu Feb 14, 2008 7:15 pm
stating the obvious, but still............
PostPosted: Sun Feb 24, 2008 1:26 pm
Captain Caution !
Simon
Can anyone suggest a source for milk crates? I've looked in Lowe's, LnT, and Target.
Simon
PostPosted: Sun Feb 24, 2008 3:39 pm
Try places like Hold Your Own, office supply places, etc. You can also google for "material handling" companies and many have more industrial type solutions that will likely last a lot longer than the cheap crates that you'll find in stores. They'll basically be less brittle and thus more durable plastics.
PostPosted: Sun Feb 24, 2008 4:39 pm
I'm sure the Pine State Creamery on Glenwood Rd would have a few extra milk crates laying around.
What? It's gone? Damn, when did that happen?!??!?! :wink:
PostPosted: Fri Feb 29, 2008 7:42 pm
Simon
Look around the back door of elementary school cafeterias. There are usually stacks of them there.
PostPosted: Fri Feb 29, 2008 8:47 pm
take a picture of the area, make me up a sketch of what you want with measurements and ill get one of the mooks at work to weld you up something. tubing or angle or sheet metal, lemme know.
also i can bring it up to the next rally
PostPosted: Fri Feb 29, 2008 11:07 pm
Simon
Simon
My kangaroo station in Fuquay leaves them laying around out back. I can get you some if you know how many you need.
~ RallyX VP 2009 ~
'92 Prelude
'76 Celica
