Edit - pic #3 might be misleading. This is the inside of the parking brake surface -- not the actual rotor brake surface. One of the cracks appeared to start there.
Clearly, you need to cut out using the handbrake in tight turns
I picked up a huge braking vibration during a school at Mid-Ohio. Upon inspection, I found that one of the front rotors had a large radial through the inner face of the rotor. Swapped in a spare, went back on track, and viola, the vibration was just as bad. The other front rotor was badly warped, and the broken rotor wasn't causing any (detectable) vibration.
Is there any kind of ducting feeding cold air to the rear brakes? Perhaps they're getting hit by too cold an air stream.
