 Post subject: E36 Brakes
PostPosted: Mon Jan 07, 2008 1:34 pm
I miss my Type-R
I've got to replace the rotors and pads this year. I've read that floating rotors minimalize warpage and greatly imporve life, but the cost is about twice as much. Any thoughts? If it helps, I'm very hard on tires just from my daily driving.
Also, is Matt still around and THE guy to go for for pads? Anyone have a contact?
One more thing. How are you guys bleeding brakes, any special tools, good bleeders, etc? Are there gotcha's I need to know other than replacing the sensors? Thanks!
1990 Honda Civic SI
 Post subject: Re: E36 Brakes
PostPosted: Mon Jan 07, 2008 1:58 pm
There's tons of opinions on pads. I'm running the Hawk HP+ right now on stock blanks and I'm pleased, but not good for the street as they dust and squeal under normal street driving. I'll let Mike and some of the other bimmer guys give guidance to pads.
As for a bleeder, lot's of folks in the club have one. You're welcome to borrow mine if you like. No special tools needed outside of some basic hand tools and some ratchet driven allen head drivers. Siphon out as much of the fluid as you can from the reservoir and then start to replace/bleed the brakes. Just start at the right rear and work your way backwards to the front left and you're good to go... but you know all this already...
http://www.motiveproducts.com/
As for the sensors, no need to replace unless you have a brake light lit up on the dash.
PostPosted: Mon Jan 07, 2008 2:32 pm
OE Brembo/Balo/Zimmerman rotors from Black Forest or Bimmerworld are totally fine for anything you can throw at the car.
Pads - OE (Pagid/Jurid/Textar) are great but dust a lot. Axxis Ultimates are also excellent with a lot of dust. I run these for street and autox. Axxis Deluxe doesn't dust as much but loses some bite -- it's an organic pad. Lots of people like Axxis Metalmasters but I have always found them to be very rotor-unfriendly. All available from Black Forest or Bimmerworld for best prices. Not sure what Matt is selling these days, you could give him a call.
Bleeding - you can bleed the M3 just like any other car you've owned. I've never used the fancy tank bleeder like Rodney has but I do have and use a pressure cap to make it a one-person job.
Brakes are pretty straightforward. Use an electric impact to free up the hex head rotor (tends to keep the hole intact). Need allen hex sockets for the caliper pad removal. Check your dust boots when the pads are out -- if cracking, rebuild the caliper. The anti-rattle springs can be a bit of a pain until you learn the "easy" way to remove and install.
I'm a big fan of ATE Typ200 (NOT blue!) fluid, it has never let me down.
PostPosted: Mon Jan 07, 2008 2:51 pm
Depends. Company he's with now, BHP Brakes, makes pretty much only track oriented stuff. It's very very good though, I've got them on my S2000 and they're brilliant, they work quite well as autocross pads. They do generate a lot of dust though.
http://www.bhpbrakes.com
PostPosted: Mon Jan 07, 2008 4:25 pm
Ken at KNS brakes has the best prices on Hawks and he's local.
brakeguru@gmail.com
PostPosted: Mon Jan 07, 2008 11:14 pm
I miss my Type-R
Got a contact for BF? Also, where is ATE sold in the Raleigh area? Down here in the sandhills, I'm not seeing it.
1990 Honda Civic SI
PostPosted: Mon Jan 07, 2008 11:22 pm
Hey Phil - I've got a Motive power bleeder you can borrow.
I've only got the universal round and rectangular fittings though. I've got to get one that fits the Focus - found out that the round one doesn't work :evil:
PostPosted: Tue Jan 08, 2008 1:57 am
Black Forest - 468-5400. Adam Ligon is part owner, Matt usually answers the phone and generally knows his stuff. They have ATE fluid in stock, but call first to verify. If you don't get to Cary often you might be better off with Bimmerworld since most stuff arrives overnight. If Rob K answers the phone he's quite knowledgeable but very opinionated and has a racer mentality, don't let him change your mind if it's based on good decisions.
PostPosted: Tue Jan 08, 2008 11:51 am
brakeguru@gmail.com
+1 For Ken. His prices were as cheap or cheaper than anywhere and he will price match. He stocks a lot of Bowel Movement Wagon pads.
PostPosted: Tue Jan 08, 2008 2:16 pm
last time i bought ATE at BFI it was like $15. wtf?
the VIR pro shop sells it for $12 so i just buy it there now :P If its not a track car, it gets the prettiest $6 bottle at autozone.
