Well, it's time to pull the trigger on some front camber plates for the 328 so I can stay competitive this year. Right now I'm looking at some KMAC stage 2 plates. The guy at Turner recommended these and I can use them w/ my current non-coilover Bilstein struts. If you have recommendations on other plates that won’t wreak my budget, let me know.
I need to replace the bushings on the rear of the car as well. I'm still on the original stock bushing and w/ 170k on the car, I think it's time to replace at least the trailing arm bushing. I was thinking about replacing the lower control arm bushings with some of the camber bushings that BavAuto has for sale, but I have some concerns there. They are.....
> cost, ~250 for a set of camber bushings
> is using cambered bushings in the lower control arm legal for STS? From what I can tell from 14.8.H, I can replace the upper arm, but that’s price prohibitive at ~600 for the pair from Turner.
> can you get the recommended -2.5deg of rear camber from using stock components?
I’d appreciate some feedback from the bimmer drivers before I spend my money. I have ~1500 to spend and already burned up 500 on tires, and I still need to spend 200 on front hub bearings and 350 on camber plates. I also need to have the tires installed/balanced and have an autox alignment. My remaining money needs to be spent wisely….
Thanks all and have a great New Years!!
