 Post subject: Doing a Brake Job on the BMW
PostPosted: Thu Dec 13, 2007 6:00 pm
The 330i needs rear brake pads, so I figured I would do them all. Also when my parents had it in for service the last time they told them to replace the fluid which I usually do any way. Do BMW require any "Special" brake fluid, I have always used Valvoline Sythtech and had good luck with it, or is there a BMW labeled fluid I should be using. Are there any tricks that would make my life easier?
Thanks!
David Teague
2015 Lexus IS 250c
1994 Honda Del Sol HS 39
2009 Dodge Journey R/T
http://teaguefamily.us
PostPosted: Thu Dec 13, 2007 6:49 pm
Keeper of the Noobs!
I always used ATE...I mean hey, it's german
traded the ultimate driving machine for a hatchback.....
PostPosted: Thu Dec 13, 2007 9:02 pm
The brake job is completely straightforward with no tricks needed that I can think of. Any DOT4 fluid should be fine. I usually use either ATE or Motul 600 in my cars.
PostPosted: Fri Dec 14, 2007 2:07 am
For a street car anything off the shelf is fine as long as it's replaced every 2-3 years. If you care about the car stick with a reputable can of stuff. ATE Typ200 is my choice for damn near everything I own. Black Forest usually keeps it in stock, I just picked up a can this week for my 330.
