 Post subject: Micro Camera Shows the Inner Workings of a 4-Cylinder
PostPosted: Thu Oct 11, 2007 7:19 am
One of the gents in the ITR forums posted a neat link this morning:
http://www.gizmodo.com.au/2007/10/micro ... rking.html
"Someone had the great idea of putting a high-pressure, heat-resistant camera inside the cylinder of a four-stroke engine. Shooting at 1000 fps, the camera recorded just exactly what happens to make engines run. Suck, Squeeze, Bang, Blow!"
PostPosted: Fri Oct 12, 2007 7:32 am
I miss my Type-R
First off, is this real?
If it is, it would be interesting to know what engine this is as it doesn't seem nearly as violent as what I had expected.
1990 Honda Civic SI
PostPosted: Fri Oct 12, 2007 7:34 am
I wish that they would show more of the cylinder evacuation through the exhaust valve.
PostPosted: Fri Oct 12, 2007 9:25 am
I watch this and think two things...
1. Is it fake? Something just doesn't seem right? I guess I am looking for a more controlled burn as well as it seems like it is pulling more air/fuel into the cyl than I would expect. I also don't understand why the camera seems to vibrate around as much as it does. I can imagine it vibrating due to the engine operation, but it seems to be vibrating at a rate higher than the apparent RPM of the engine. But maybe it is shockwaves in the block/head that are causing it.
2. It probably is real and maybe it is just challenging my pre-conceptions?
Related video that is pretty cool. Shows animated construction as well as operation of a 4-cyl, 16-valve, DOHC 4-cycle engine.
http://www.youtube.com/watch?v=0EMeQxImNmk
PostPosted: Fri Oct 12, 2007 9:52 am
A real video
Another forum has speculated that the first video is a model of what happens; the indicator of that is that the valves aren't rotating as much as they would in real life.
PostPosted: Fri Oct 12, 2007 1:03 pm
That was an awesome four minutes. Any idea what type of engine that was?
