PhilFausz wrote:
Richard Casto wrote:
I am curious, short of it pulling out enough that there are no splines engaged and you then loose all drive to one wheel, how would it cause the pulling? On the Honda you have that ring on the end that holds it in place and I am guessing that once that is released you would have to pull it a good inch or more out to loose drive and once out, I don't see it popping in and out (sometimes working and sometimes not). Or is something else going on here that I just don't understand?
If this is the case, I don't think it's pulling out totally, just enough to affect the ride. I would think the axle moving even a 1/4" would cause serious ride issues. The other reason I suspect axle issues is because this only happens when I really get on the gas. If I floor it in first, I fight to keep it off the road. If I floor it in fifth at 40 mph, it pulls, just not as hard.
Of course, I guess if several bushings are shot, they could also play a huge part.
If it's the bushings, I'll have to fix my oil leak first, then worry about bushings. If it's not one thing, it's going to be ten others.
It should be pretty easy to test to see if the axel is loose. I don't know if you have replaced one before, but there is a ring clip that holds it in place. If that clip is not engaged, I would think you could grab the inner CV and slide it in/out a bit. If it does this, see if you can tap it back into place (without tearing up the CV boot!) You should feel a positive "snap" when it does this. There is not much holding it in place as there should not be much axial thrust on that joint.
Oddly enough I have a reoccuring leak in this area on my car. The seal that the inner CV passes through on my car seems to start leaking after X number of miles after it has been replaced. I am thinking there is an issue with the remanufactured axel I am using on that side.
I am still puzzled about how this could cause ride issues. I do think if it is loose it could cause odd vibrations, wear on the spline (both on the CV and diff) as well as eventual loss of drive. But what we are talking about is a CV join and the other end of it (axel) is already designed to slide back and forth a bit anyhow.
