I'm about to replace my original exhaust. There are several leaks and there maybe leaks in the downpipe, I'm not sure yet. I've looked over the SCCA rule book for restrictions:
Any part of the exhaust system beyond (downstream from) the
header/manifold or catalytic converter, if so equipped, may be
substituted provided the system meets the requirements of 3.5.
Stainless steel heat exchangers are permitted only if the physical
dimensions and configuration remain unchanged.
Since the downpipe is between the header and the catalytic converter, what are my options for replacement? Do I have to have an OEM downpipe (unbelievibly expensive), or can I use a non-OEM one of the same diameter, or something else? I guess the other option is to try to patch any leaks, but I'm not sure how successful that would be.
