Donnie Barnes wrote:
robharvey wrote:
I'm definately interested. With the FSAE car, I can't jump out on the highway to "feel out" the car. I'm interested in a larger skid pad and an 8-10 cone slalom. The suspension on the car definately needs to be TUNED!
You need to give is a suspension first. I definitely felt like it just rode the rubber bump stops when I had it. Perhaps there's something you can do with those shocks, but I doubt they're ever going to be very useful. I'd suggest figuring out how to rework the thing a little to accept motorcycle shocks (the ones sport bikes use on the rear). Even then you won't get but an inch of travel, but that's probably enough for most places in that car.
Then you need to put one of these Quaife diffs with integrated reverse on it:
http://quaifeusa.com/Motorcycle/cycle.h ... lecars.htm
I agree Donnie. I don't think there's much that can be done with the current shocks. I'm looking at alternatives. I made changes for the Danville event and the car was really bad.
The set up that was on the car when I got it from you had 800 lb/in springs on the front and 300 lb/in on the rear. The motion ratio in the front is .5/1 (or 1/2) and the rear is .75/1 (or 3/4). There was no droop in the front (and hardly no bump either!). There was next to no droop in the rear (with driver in the car). I think I figured out some of the rational for this setup. The LSD was worn out (brass friction rings were worn out), so it acted like an open diff. Any time the rear wheels lifted, you could put power down on the pavement. So, since the car doesn't use swaybars, I believe, the stiff springs in the front (800 lb/in) were put in place to limit roll and help keep the rear wheels on the ground (and it definately did help with that). But with very little droop in the rear, the rear tires where still coming off the ground. I couldn't feel it because I had put an 80% LSD kit on the car, but thanks to Spratte's awesome photography work, I could see the inside rear tire was slightly off the pavement as I was going through the slalom.
So, I dropped the front spring rate to 300 lb/in and increased the rear to 350 lb/in (primarily because that was the only matching pairs of springs that I had access to). When I corner balance the car (inc driver weight) the front tires have 170 lbs each and the rear have 210 lbs each (total of 760 lbs). But the car handled horribly at Danville. The suspension was binding on rebound (e.g., push down on the suspension and it would only partially rebound and wouldn't rebound to the same point when repeated). I also had alignment problems that I was able to correct in between morning and afternoon runs. But the car had way to much oversteer and was too soft.
One other design issue with the car is that they offset the engine so that the chain drive would be centered on the chassis (thus they didn't have to deal with using different lenght drive axles). This puts more weight on right rear (~ 50-70 lbs). So, when I set the ride height where I want it, the corner weight is out of whack. When I balance the corner weights, the chassis is tilted to one side (@#$%&).
So before I head to a TnT. my goal is to resolve the following issues:
1 - work on spring/shock setup
2 - look into possible sway bar setup
3 - resolve the shifting issues
4 - fix that damn warped rotor!!!
