 Post subject: Hub Rings?
PostPosted: Mon Jul 09, 2007 8:56 am
I need a pair of adapter rings to center the hubs of my new Cobra rotors on the car. 70.3mm OD x 57.1mm ID. Anyone know where I can get a set of these for a reasonable cost? I tried www.emachineshop.com and they wanted almost $180 for them. That’s not what I had in mind as reasonable.
PostPosted: Mon Jul 09, 2007 9:53 am
is it an odd size or something? I got a set of rings for my wife's mini (I think they were 56.1x73.1, and they were 39.95+shipping from Tire Rack. Discount probably has them too.
PostPosted: Mon Jul 09, 2007 9:59 am
You do all the research on the brakes and cant even type Hub Rings in google.... :roll:
Close
Closer
 Post subject: Re: Hub Rings?
PostPosted: Mon Jul 09, 2007 10:03 am
You need something to mount the hub on the car, or the wheel to the hub?
If the former, then for sure you'll need something custom. For the latter, regular spacers will work.
Jeb/Discount Tire keeps a LOT of hub rings in stock. I got some for the subaru there. But, they are all plastic. For a track car I'd stick with metal.
PostPosted: Mon Jul 09, 2007 11:00 am
I need something to center the wheel/rotor on the hub. After more research it seems the Mustang center bore is 70.5mm (not 70.3) so I need 70.5mm OD x 57.1mm ID.
The website Ryan linked to has something close, so I wonder if 70mm x 57.1mm will work OK? Will that 0.5mm (1/64") be that big of a deal?
PostPosted: Mon Jul 09, 2007 11:14 am
Tire rack definitely carries metal rings, I replaced my plastic ones that came with my wheels.
.5 mm is probably a pretty big deal, I'd get them oversized if anything, and machine them down if you can't find the proper size. I see some in 71.12x57.1 that wouldn't take much machining, if you have access to a lathe.
http://www.1010tires.com/hubrings.asp?g ... gQodrBl21A
PostPosted: Mon Jul 09, 2007 11:17 am
OK, I think I get it. Rotor is loose on the hub, and you need a ring to center and locate the rotor. Keep in mind that wheel hub centering rings are usually designed to be pressed into the wheel and as such usually have a lip which keeps it from being pressed in too far. If you need the ring to locate the rotor also, then this ring will probably prevent you from doing that -- unless the rotor also has a chamfered edge on the backside. Then you would be able to put on the hubring, then the rotor, then the wheel. That might work. Depending on the thickness of the rotor hat, though, wheel hubrings will probably be too short to also provide for the wheel centering. I still think something custom machined at 0.05mm undersize for a solid interference fit might be preferable.
IMO, that 0.5mm is going to be a problem. For a wheel it may be no big deal since the wheel lugs end up providing centering, but the holes on the rotor are a loose fit and don't give centering. I think 0.5mm potential "wobble" in the rotor is asking for vibration problems.
PostPosted: Mon Jul 09, 2007 1:33 pm
Cool. OK I've decided to order the oversized OD ones and go from there. I have a former co-worker who's BF is a machinist so maybe I can get him to modify the OD for beer or something. If not, I'll give it a try myself.
Stay tuned...
PostPosted: Mon Jul 09, 2007 2:23 pm
I've got a access to a lathe at work that would be able to handle what you're talking about. Let me know if your other option doesn't pan out. I'm in RTP though, dunno how convenient that is for you.
PostPosted: Wed Jul 18, 2007 3:58 pm
Vincent once you get the rotor centered weld it to the caliper mounting bracket so you won't ever have to do it again........
Always here to be helpful!
Ron
PostPosted: Fri Jul 20, 2007 11:57 am
who's BF .
OMG did you like really type BF. You are like way cool. I bet you text all your BF's :lol:
PostPosted: Fri Jul 20, 2007 12:06 pm
who's BF .
Hey, you are the one who sleep with Ryna mister! Not that there's anything wrong with that. :P
