Thanks everyone for the info....
Kevin, I will play with that spread sheet.
I may convert it to use published tire diameter instead. I wonder if tire/tread width and aspect ratio is going to be accurate enough?
Dick, Yeah I know about the Dyno issue.
Right now I am looking at comparisions between four cars...
96-00 Civic LX 1.6L SOHC no-Vtec
96-00 Civic EX 1.6L SOHC Vtec
99-00 Civic Si 1.6L DOHC Vtec
02+ Civic Si 2.0L DOHC Vtec
I currently have the LX model. The EX and 02 Si are just for comparison purposes. The only car in this bunch that I might switch to is the 99-00 Si.
The dyno info I have comes from Comptech. They have published baseline info (actual values for every 200 RPM) for the those three cars. These dyno baselines are used to show improvements when using their headers and exhaust. I believe they are from the same dyno as well. The three 1.6L baseline values seem to track pretty well at low RPM (a few HP of each other) and that makes sense to me. The peak values also match well with specified HP when using a 13% drivetrain loss. It is on the upper end where things change and the EX and Si make more power at higher revs.
If will get really hairy if I start looking at dyno values for other cars and try to compare those to the Honda values I have.
