BriceJohnson wrote:
I was suggesting an either or. Either, get the matched set of bars, or go with a smaller rear bar. My main point is that I think its the huge rear bar causing the oversteer, probably not a camber issue. The unfortunate thing is that nobody makes an "in between" rear bar. Its either the 22mm bar I have or the huge 27 mm RB bar.
And Mark and I spent some time discussing this as well. Given the car's tendancies and my level, he felt the -3 would be a nice fit for what I was experiencing.
Now the rear has been adjusted and I am coming back for the front. Based on what I feel right now with zero toe F/R -1 in the front and -3 in the back, in harder city driving the rear seems to be planted a lot more. There is a particular exit ramp that I will push the car through rather hard and the back has often felt like not much would unsettle it. As it is now, is seems to bite a little more, while still rotating (not wanting to push as much).
I know that this sensation may totally change in an autocross situation, but a lot of the same sensations that I felt on this ramp I have felt during an autocross as well. I guess the nice thing about adjustablity, is that I can do this and see how it works/feels and still have room to change back to a smaller bar in the rear or a bigger front bar. IIRC, H&R has a 25mm rear bar, that may be a good in between. At the same time I don't really want to keep pumping $$ into rear bars. The bigger front bar from Racing Beat may calm things down as well, but like was stated above make some of the power transfer sketchy.
So Mike, now that it is a legal mod, are you up to help a brotha out?
