 Post subject: M3 & Kosei's?
PostPosted: Sat Mar 03, 2007 10:18 pm
I miss my Type-R
I'm considering buying a set of Kosei's for my 1998 M3. Anyone out there running these? I'm in the process of seeing what fits (tire and wheel) a stock M3. Also, does anyone suggest an alternative wheel for around the same price? Thanks.
Phil
1990 Honda Civic SI
PostPosted: Sun Mar 04, 2007 9:36 am
Phil,
I think PJ's running those on his E36.
PostPosted: Mon Mar 05, 2007 8:35 am
I miss my Type-R
I contacted John at the TireRack and found out that a 235/40 will fit without spacers, but wider tires will require spacers.
Phil
1990 Honda Civic SI
PostPosted: Mon Mar 05, 2007 10:26 am
Keeper of the Noobs!
255 Azenis with 15mm spacers up front will fit. With stock springs I didn't have to roll the fenders. With H&Rs you will have to roll the rear a little.
traded the ultimate driving machine for a hatchback.....
PostPosted: Mon Mar 05, 2007 6:17 pm
i ran em w/ H&R Sports/Bilsteins and GC coilovers, 255/40 Azenis, and 12mm front spacers.
I rolled the rear fenders a bit, but i'm not convinced it was totally necessary.
PostPosted: Mon Mar 05, 2007 7:44 pm
size issues are usually seen on the front wheels. it is more the inability to turn lock to lock without dragging the inside of the wheel well.
probably not critical for autoX, not real good for track.
PostPosted: Mon Mar 05, 2007 8:36 pm
i tracked the setups and didnt find any trouble either. you'd likely use a lot more steering input in an autox than on track anyway
