 Post subject: E36 M3 front hubs
PostPosted: Fri Mar 02, 2007 10:28 am
Anybody know where to get these local?
TIA
Tim
PostPosted: Fri Mar 02, 2007 2:16 pm
Adam at Black Forest in Cary should be able to get them by this afternoon or tomorrow for (estimating) around $50-60 each.
FYI Partstrain.com is a near-copy of Worldpac. Black Forest's part availability matches partstrain.com about 99%, and they are always cheaper -- much cheaper on small parts.
Partstrain page for E36 M3 wheelbearings: http://www2.partstrain.com/products/Eng ... --003.html
PostPosted: Fri Mar 02, 2007 9:23 pm
Mike,
Are you able to change out just the bearing or do you need to replace the whole hub? I've seen the hubs listed for around $90.
Tim
PostPosted: Fri Mar 02, 2007 11:49 pm
TimPeele wrote:
Mike,
Tim
I'm sure you could do the bearing only, but if it's anything like the E30 (haven't had to touch them on the M3) then replacing the whole hub is the way to go.
