How are the rest of the mounts? New? Poly? Torn?
This is on the rally car. All three mounts were new, polyurethane from VF Engineering. The other two seems fine.That metal may have bent *after* the poly tore -- once the engine can slop around the forces could certainly have rounded out the hole.
Is the aluminum part of the mount stock?
None of it is stock.Can the metal part be reinforced?
Can you use an alternate engine location device like a chain to inhibit motion in the direction that is a problem? I know some autocrossers do that.
Could you add plates to the side of the poly mount to inhibit flex?
Hmmm. All good questions. Don't know.Any chance that something hit the mount to start the bending of the metal?
It is the rally car.
Could the poly have been torn or damaged during or before installation?
I did the install and don't recall it being damaged.Poly mounts from a reputable company?
VF Engineering.What do they think/suggest
I'll ask.
