George Bright wrote:
My friend Bob has been handed a 90 or 91 Eclipse with 2000 twin cam motor. The people smelled smoke in the interior and the car quit. We have found inside the brain an electrolytic capacitor blew up on the board frying several traces.
The question is it likely that a new $350 brain going to fix it or is there some other problem that causes these cars to eat brains? The car is in very good shape as far as the body. The interior is so so, and it ran well up until this problem.
Yes a new computer will probably fix it. I would check out ebay for a used computer. You should be able to pick one up for a lot less than $350. If you do get a used one, open it up and replace those three caps. ALL of the DSM ecus had the problem with the caps leaking and eating away those traces. It only cost about 75 cents in parts to save the ecu.
