Aaron Buckley wrote:
KYB's are stock legal. Stock legal is defined by attaching at the same mounting points and being within 1/4" of the stock length of the shock (both body and shaft). As far as shocks go, the KYB's aren't too bad. The only downside is that they are not guaranteed for life like the Konis, and they adjust rebound and compression at the same time, which can be a detriment at times. - AB
He's talking about the KYB replacement bumpstops, not the shocks. The shocks are a great deal for the car although I do prefer the Konis. I used to use the KYB shocks with my current spring setup (450/300 Ground Controls) and switched to the Konis. The Konis seem to deal with the higher than stock spring rates better than the KYB's. The KYB's would get harsh when adjusted to deal with the stiffer springs but for softer rates (like the recommended GC rate, 350/250?) or the stock springs, they were pretty good. I really need to get the Konis revalved since they are currently using the off-the-shelf valving but that is yet another project for the offseason.
As far as the KYB bumpstops being legal, I have no idea. I just know that they seemed stiffer than the OEM bumpstops and prehaps not as progressive which caused which ever end that hit the bumpstop to wash out suddenly. For non-aggressive driving, they were fine but for anything approaching auto-x aggressiveness, they felt terrible to me.
