JamesFeinberg wrote:
I have an old WD hitch you can have. It is in great shape and has less than 5000 miles on it.
Anyway, let me know if you want it and I'll dig up the pieces.
Sold. It seems like a fine way to see if it's something I want. If it's great, and it's out of date/inadequate somehow, then I could always upgrade.
Wes Eargle wrote:
II'm surprised that you didn't look for one after that little agricultural excursion that you had coming back from Laurinburg a couple of years ago.
It was only the trailer that went agricultural, the truck was rock solid through the entire event. I never felt the trailer trying to pass the truck, I only saw it in the mirror.
The new truck should do everything better than the old one (longer wheel base). I ran helper air-springs on the old truck (and they went with it) in order to do load leveling with a trailer attached. That was my band-aid. Since I never used them for anything else, I've just decided to get the right tool for the job this time around.
Come to think of it, I may have had the front brakes lock up a few times on damp roads, specifically for the reasons Mike mentioned.
The other "issue" with the air springs was the damping of the stock shocks, I could add enough spring rate that the truck was under damped and was just as bouncy with the springs inflated as without. A weight distributing hitch eliminates much of that "bounce."
