BretLuter wrote:
The Konis I have on my BMW E30 (rear) have a small button on top of the shock body that you have to push while you compress and turn the shock body.
Maybe this will help:
http://www.amdtechnik.com/technical.koniadjustment.cfmBret
Mine are similar but without the button...
Wes Eargle wrote:
1/2 firm should be fine on your street car. How much of a pain in the rear is it to pull the rear dampers? When I was in STS, I ran the biggest rear bar that I could find -- 21mm. I found that the car would rotate nicely with more rear rebound firmness dialed in than that, but then again it was easier to make the adjustment. With the single adjustable Koni Sports, you're adjusting rebound only -- not compression.
You'll learn pretty quickly how to tune the rear with air pressure rather than turning a knob.
My hopes are to have something that firms things up. I already have a 27mm rear bar and the backl rotates pretty easily now, as I found out in Sanford.
Removal looks pretty easy on my car.
http://www.icestormdesign.com/mwcc/mazd ... 00W01.html
The thing I am not able to grasp is the adjustment for the rears. It kind of seems like a shot in the dark...
