One rallycross and I got hooked. So I need to build a suspension that will replace the set up that helps me with my incredible autoX finishes
I wanted stock springs from a heavier VW matched to some heavy damped shocks. The plan with the shocks/struts was to take whatever showed up, drill them, braze a fitting in, and replace the stock oil with some straight motor oil, 30-50w? depending on the experimenting.
So after some inquires I got a line on these, from a later Cabriolet:
Dirty, grungy, but a little bit of dirt removal showed:
AND
So now the plan is to take every thing apart, clean it up and make sure the dampers still work. If they do, I will apply some Red Lantern stickers and have them ready to install for the next RallyX. Should be a big improvement, over the very stiff Bilstein setup. The sway bars will also be getting a rest.
