All this talk of pressure zones and $300 sealed brake ducting mechanisms and where to point the thing is great, but...Jason has a FWD car. So my suggestion is this.
Route them in such a way that they at least point somewhat close to the rotor (I too am in the "rotor" camp...good fluid doesn't boil). Your more important considerations are keeping the things out of the way. Brake ducting on a FWD car, from my experience with the GS-R, is a pain in the rear. You've got CV boots, calipers, tie rod ends, swaybars, shocks/springs, and lots of other stuff in your way. So get it the best you can, and then keep careful consideration of the following points...
1. Keep them away from the drivebelts and pulleys. Especially if you're using ducting with a metal spiral "core." Doesn't take long for a pulley to wear through the silicone, expose the metal, and start cutting things. Belts, your hands, CV boots, I've seen it all.
2. Keep them away from the tires. I know, "You never use full lock on a road course so who cares?" The reason you care is if the tire hits it, it moves the duct to a different location. Such as rubbing up against a CV boot or pulley. See item 1.
3. How do they work when the car is on the ground? A lot of configurations I've tried look fine when the car is up in the air. But enough stuff moves around when the suspension compresses that the configuration gets screwed up. Back to items 1 and 2.
4. Ground clearance. Once you've got them out of the way of everything, they may very well hang too low. The first time you go off, or even straddle a piece of curbing, you stand a good chance of ripping them off the car. Then anything can happen. Worst case, it wraps itself around a driveaxle, ruins the axle, and your weekend.
You may not be able to account for all of the above - I've yet to manage it on the driver side of the Integra.
_________________ Karl S. 2014 Baby, 2014 House, 2013 Ford Focus ST, 2013 BMW 328i, 1994 Mercedes E320 (Insert passive aggressive signature line here)
