 Post subject: Power Bleeders
PostPosted: Fri Sep 08, 2006 8:51 pm
Does anywhere in the Raleigh area sell power bleeders?
PostPosted: Sat Sep 09, 2006 10:42 am
These people deliver
http://www.ajusa.com/cgi-bin/store/view ... a7eedf145f
 Post subject: Re: Power Bleeders
PostPosted: Sat Sep 09, 2006 2:38 pm
Autosport Gallery in Raleigh has them. Give Tom a call...
FYI...if you need it, he probably has it or can get it for you quickly. He knows his stuff.
PostPosted: Thu Sep 14, 2006 2:01 pm
STopped by Auto gallary today, he is now operating it out of his house at 536 Cooper off of Poole rd. The bleeder did cost more than ordering and shipping from anywhere else, oh well.
PostPosted: Thu Sep 14, 2006 2:35 pm
I've built two custom ones for friends. All ya gotta do is ask man.
PostPosted: Thu Sep 14, 2006 3:56 pm
I saw you had one but I didn't notice that it was a VK Specialties! T
PostPosted: Thu Sep 14, 2006 4:05 pm
When I first bought some Marchell H4s from Tom many moons ago, he was selling out of his house. And it was a little more expensive than mail order but I got what I needed. Sometimes thing come full circle.
PostPosted: Thu Sep 14, 2006 4:59 pm
Mine is the Motive Power Bleeder. At the time I ordered it I had several projects going on (Corvette brakes for one) and didin't want one more. I've since made one for Randy's Mustang and Tom F's RX-8. The cost is a little less than the Motive one, but not much less.
PostPosted: Thu Sep 14, 2006 6:16 pm
i recently saw one that was powered by an air compressor. kinda pricey and requires about 90 psi. glad i could help :roll: :roll:
PostPosted: Fri Sep 15, 2006 12:08 am
90psi !!! all you need is 10-15psi max. that's why the simple hand pump is sufficient.
if you like making your own tools you can get small pressure sprayer at HD. then a pressure gauge, hose, brake fluid reservoir cap, a couple of small clamps, some silicone and presto. home made bleeder. i decided to just buy the Motiv unit. it isn't that expensive and i'm getting my moneys worth out of it.
PostPosted: Fri Sep 15, 2006 9:47 am
I'm not too sure a brake reservior could take 90psi. I have a feeling it would blow it off the master cylinder.
2004 C5(415whp,390ft/lbs),
1997C5,1997Trans Am, 1986 C4,
PostPosted: Fri Sep 15, 2006 9:59 am
I'm sure you are correct! I use 10-15 PSI on my power bleeder.
PostPosted: Fri Sep 15, 2006 10:14 am
it doesn't work off the master cylinder. it draws from the wheel.
PostPosted: Fri Sep 15, 2006 12:34 pm
Even the hand held Mity-Vacs don't need more than about 20-25psi to suck the fluid through.
Given a choice you are better off pushing the fluid through from the reservoir under pressure than pulling it through the bleeder. People have had problems with the Mighty-Vacs causing air bubbles in the calipers.
PostPosted: Fri Sep 15, 2006 6:09 pm
yep that's one reason I got the power bleeder
