I'm not a track guy, but have to dissagree with the statement that "any street tire is trackable". I'm sure other examples exist, but in my experience the BFG G-Force KDWS is absolutely not a trackable street tire and I think many "all season" tires fall into this catagory. The KDWS's that came on my GTO after 10K street miles, I tried autocrossing on them . One day in L-burg and another in Sanford, and they were destroyed, corded in many spots and unsafe to drive home had in been raining. When Motorweek tested the GTO they found the same thing, severe chunking of the tires after just a few laps around their test course, causing them to stop testing prematurely.
The KDW would probably be fine, as would most street tires, but I wouldn't be recommend a true all-season snow rated tire, and absoutely not the KDWS.
Couple things...
First, my main point was that there will be compromises either way... but BEING a track guy, I know first hand that all-season tires can and do make perfectly fine (and very fun) track tires. Sure... they won't have the best grip, but for an HPDE you don't NEED the be-all-end-all of grippy tires. Part of the fun is learning how to drive the car fast on street tires (without tearing them up). Learning the differences between the sounds they make (is it a happy squeal, or an angry howl?). Its also very gratifying keeping up with, or even passing similar cars with 'better' tires. You can drive to, on and back home on the same set without worrying about the weather or every little bit of road debris ruining your expensive ultra-high-mega-sticky performance 'street legal' tires.
Secondly... Dan has a '97 M3... a touch lighter and a touch less powerful (but a might more balanced) than your GTO, and (I know I'll get flamed for this one) I'd argue that HPDE, especially in the instructed groups, is (or at least should be) easier on tires than most autocrosses. But that was also one of my points about WHERE he plans on tracking. Track surface and the type of turns plays a huge role in how long a tire will last (in addition to track temps as well). The Yokohama all-seasons's I had on my BMW absolutely LOVED VIR South Course
(video... just listen to 'em squeal for joy), but when I took them to Roebling Road in June, I toasted them.
As far as my recommendation, I stand by it. Even though I said KDW, I was actually thinking of the KDWS, which would be the equivilent of the NLA Comp T/A VR4 which I ran on my automatic 1990 300zx at almost 3700 lbs... without any problems (granted, I wasn't that fast in that car, but still). If Dan does indeed want to keep a treadwear rating to 300 or better, then the KDW or G-Force Sport would be the way to go there... I just picked BFG to mention, there are tons of others that are probably better and cheaper. (I'll be running my E30 325 on Khumo V711's at rockingham in Nov, I'll let you know how they do.)
Please keep in mind, I'm talking about HPDE driving (5 to 8 tenths max)... not racing or time trialing.
