Just to add to what Keith said:
MarcusMcRae wrote:
How hard is it to replace the front and rear control arm bushings? Do they have to be pressed in?
Fronts are somewhat involved. Easiest if you are replacing the control arms at the same time, since the "lolipops" are hard to get off the ctrl arms. I don't know how to get the lolipops off of the ctrl arms without drilling and sawing the rubber off on the bench.
Honestly, at 60k, I wouldn't bother with the fronts at all unless you have detectable play in the ctrl arm bearings, or if you're upgrading the bushings. At 100k it's a good preventative maintenance item to do the arms and bushings together.
Once you get the lolipops off the ctrl arms, you need a press to do the front ctrl arm bushings. I have a press and have done several of these -- once you get the lolipops off let me know.
Rears are easier. I have the "special tool" to do them on the car. You're welcome to borrow it.
MarcusMcRae wrote:
Do the tie rods normally have some play in them? I was thinking about replacing these. Car has 60k on it.
Like Keith said, any play, replace them. I have found that the inner tierods develop play after 100k, but I'd be surprised at lay at 60k. Minor play in the tierods can cause some steering shimmy.
MarcusMcRae wrote:
I took off the panel under the steering wheel to try and adjust the brake pedal height and there does not seem to be any way to adjust it. The damn brake pedal and gas pedal are too close together and I want the brake pedal higher to facilitate mo better heel and toe action. Any suggestions?
I have the same problem -- pedal it too low. I believe there is a jam nut on the master cylinder input rod that can be turned. Haven't tried it or looked into it yet, but I did do this on my E30 and it worked.
MarcusMcRae wrote:
Does it have any way to check trans fluid level?(honestly have not looked in manual yet)
The side hole is either a 14mm or 17mm allen key. I have a set of allen sockets with removable hex stubs that I put in the plug and use a 17mm wrench to turn. Fits, but barely. I think the bug 1/2" set is available at Autozone -- you may need to punch the allen bit out of the socket base. The whole allen socket won't fit.
Level is "set" when fluid starts to pour out of the side hole. Open it up and stick your finger in and down a little bit. If it comes out oily, level is fine.
Bentley describes all of this well.
