Joel Heywood wrote:
I dont think thats it. The noise is coming from around the flex disc area. Its been suggested I preload the flex disc by prying the center support closer to it. Since I didnt have the book with me its probably a step I missed.
I'm no expert on the subject, but I remember hearing that the driveshaft balance is critical to everything running smooth. Since you replaced everything else that typically is problematic, could you have a bum driveshaft?
The driveshaft is balanced with both pieces together. If you pulled it apart at the splines and didn't mark it to put it together in the exact same way, I think that would cause an imbalance.
Just a thought. If you don't figure it out give Truett Ray or Dietrich at Shade Tree Garage a call - they're a great independent BMW shop
