DickRasmussen wrote:
FYI in regard to spec miata engines:
I spoke with Dennis Shaw (his shop is next to Krause and England). He can create a strong Spec Miata engine either by going through a NEW Mazda supplied engine or by rebuilding a used one. He said the total cost would be about the same. He seemed to be recommending starting with a fresh Mazda supplied engine since everything will be brand new.
But is it legal? Is it as strong as the BSI or Sunbelt engines? Are the BSI and Sunbelt engines legal? Is Tom currently on fire, or was that fire put out?
One thing I didn't mention...no use starting out on a built or even extremely fresh motor, I don't think. Start with something decent, certainly, but don't waste money by putting hours on a hot motor while you're learning the finer points of navigating road courses and race traffic. It isn't worth it.
Now that I've got a year under my belt I'm probably going to pop for a new motor. At both VIR and Road Atlanta I really felt like I was getting off key corners with just as much speed as some folks only to watch them pull me slightly on a straight or at the very least hold their ground ahead of me on long straights when the draft *should* have allowed me to pull them at least a little. That's how things were on my motor at VIR when I started this year, but no more. My motor is a crate motor that had a few races on it when I got it. It now has several events and a lot of test time on it. Grr.
