Vern Geddings wrote:
After reading some of the replies, a setup that does double duty sounds appealing. I kind of like the idea of set it and forget it.
Oh, something that has NOT been mentioned is the fact that the RS/WRX setup is slightly different from the STI setup since the WRX/RS do not have a front limited slip. As a result, when you start approaching high spring rates, most 'quick' WRX drivers (or the standard Hoppe-rip setup) was running more rate IN THE REAR than in the front. This is generally a direct switch from what an STi driver would run:
Ex:: My STi == 10kf/8kr Tein Flex setup
WRX Setup == 8kf/10kr Tein flex (for good balance).
That is purely for a balance aspect. I still think running a BIG [edit]
front bar will help with inside wheel lift and MacPherson camber loss issues on our cars (FYI -- my FSB is 32mm).
So, with what you currently are running, I am betting that the setup feels slightly pushy. You seem to be counter acting this with a big RSB, but I bet the break away balance would feel better with a 6kf/8kr (as Hackaroo #1 stated) with a bigger FSB and some aggressive front camber to counteract some of the sidewall flex the kooks have (and they generally like to have more camber on the WRXes). I dont know if the spring length on the Megans are the same so a spring change can happen or not, but I am betting you could 'try' it like that (although the rear spring is generally A LOT tallter than the rear). Changing that setup would allow you to run A LOT less rear bar with the car giving away more neutrally intransistion... you can adjust rear bar as needed, but I am sure you would be on the small side of the bar then.
With that said, I am not the WRX-setup expert. I would talk to ol' Tommy boy, or Kevin Allen as they both have a lot of wrench time in with non-front LSD Subarus, and I think they could get your setup a little more neutral without having to use a huge rear bar.
Personally, once I have upped my rates to get rid of the rear bar depedancy, my car has felt MUCH better. The only think I have considered doing is running less front bar now, which I need to check and see with the TnT day coming up.
Of course, you could just buy and STi, and 'dial the hack out'. ;D
- dow
