Graham Jagger wrote:
TB is not the choke point...
I looked at his setup last night. Definetely should flow more than the stock airbox. So Ryan, is this RB setup letting the TB run at its full potential?
The engine sounds good, no real stumbles or anything noticeable until he hits the rev limiter. The SOTP feel is quicker revs and acceleration. He fixed the vacuum hose that need to be replaced due to the swap. The MAF power cable just barely makes it to it but it is plugged in tight. The filter wasn't over oiled so it doesn't look like the MAF elements took a bath.
Not sure on Miatas. When I put one of these open breathers on my C4 I disconnected the battery and cleared the puter. Then let it relearn because I was affecting the air flow.
Other thing. Does the factory exhaust flow sufficiently to deal with the new intake or is it a serious choke point. If so, exhaust manifold, muffler, pipe diameter?
It actually is not just at redline. It is intermittent
at full throttle high in rev range 4500+. Sometimes it happens sometimes not but often enough to be repeatable. I can move the brackets around a bit. I first had it mounted where I used a bunch of the stock holes from the unmounting, but that made it rub on the brakeline, (probably not good) and covered the shock adjuster. (Definitely a PITA) hmmmm...... 3 shocks set a stiff, one at soft that should handle well
So I moved it around and rerigged the cruise control actuator. I could probably play with it a bit, but if I move it any more to the left to ease the strain on the cable, I cover the shocks.
My next step is to disassemble (sigh) and put the stock airbox in and see if the stumble persists. If not, drawing board. If so, MAS bad.
Either way, I am going to try to switch to the RX7 one. Any Gen 2 work?
Am I missing anything?
