From the looks of it MS98003T is a complete kit with valve cover gaskets. Might as well replace all old gaskets while you have it apart. MS90565 is just the intake manifold and plenum gasket. Find the the thermostat and gasket also and get one of those.
Forget Parts America. Order that MS98003T kit from Rock Auto (
www.rockauto.com). $68 instead of $102 ...
Shame you can't just yank the intake with plenum and all the other crap attached. Would make short work of it.
There is a trick to getting the back 3 plugs and wires but I'm not sure it would work on a van. You can disconnect a couple of mounts and actually rotate the engine forward to get your mitts in there
Graham
