Post new topic Reply to topic  [ 162 posts ]  Go to page 1, 2, 3, 4, 5 ... 11  Next
 Post subject: Let's talk about your car/mods/plans!
PostPosted: Thu Oct 13, 2005 3:40 pm
i'm in need of more tech talk (and things to do at work :P ) so lets talk about our cars, the mods, the plans for it, etc, etc. id like to know more about different cars, etc.
I have the red R32 w/ CAI, chip, RSB, konis, H&R springs,.. and.. poly dogbone bushings. i think thats it. i dyno'ed it once and got 222 4whp. oh and i'm running -1.5deg of camber up front and -1.0 in the back.. best i can do w/ factory parts.
the only other thing i have in mind is a lightweight Braille battery. 37lbs off the nose of this porker can only help.
but i dont really care about me, so lets hear it.
PostPosted: Thu Oct 13, 2005 3:45 pm
Miata:
Jackson Racing cold air intake
Koni Yellows
GCs 375/250
Maruha upper shock mounts
MazdaSpeed poly bushings
Rota RB 13x8s
Some sort of Kumho tire
Five gallon can of whoopass
PostPosted: Thu Oct 13, 2005 3:49 pm
Silver STi. -1.8 camber front, -1.0 camber in back. 26mm front sway. Oem tires, 225/47/17 for now. Will go wider next year. Changing my springs soon. Engine management and custom tune with just a catted downpipe. The rest of the exhaust will be changed out on Monday. I'm keeping my Hp and Tq quiet as the other cars in SM are probably throwing down > 400 hp and Tq at the wheels and I'm not in the 4xx range. :)
EDIT: my memory is horrible. I found my alignment specs last night: my front camber is -1.2 and the rear is -1.4.
PostPosted: Thu Oct 13, 2005 3:55 pm
oct 16 - VMSC
oct 23 - TSCC
oct 30 - VMSC
Nov 6 - SCCA- Wilmington
Nove/Dec/Jan - winter series ACU-4
Jan/Feb - Evolution
Feb - Tour/Pro Atlanta
PostPosted: Thu Oct 13, 2005 3:58 pm
are you in the 3xx range at the wheel?? no way... w/ stock boost. what do STi's put down stock? i have 230ish in mind, but dont know. what kind of gains are acheived w/ exhaust? or is it primarily a spool up speed thing?
how do you like the front bar? no changes to the rear?
were you able to acheive that front camber w/ stock parts?
^^i forget my whoopass every time, doh
PostPosted: Thu Oct 13, 2005 4:09 pm
You gotta race the truck
Like to see some dyno;s of those cars putting down 400 ftlbs at the wheels. :wink:
91 Jetta GLI STS/DSP 111
85 Porsche 944 ASP 11
PostPosted: Thu Oct 13, 2005 4:16 pm
Sponsored by Wal Mart!
2001 Ford Focus ZX3
Done
  1. Header
  2. Exhaust
  3. Ported intake manifold
  4. UDP
  5. Crower stage 1 cams
  6. Mike 'The Chip Guy' Wilson Autologic chip
  7. K&N FIPK
  8. H&R Sport Springs
  9. Bilstein struts from A2 Golf adapted to Focus housing
  10. e30 BMW rear shocks adapted to rear of car
  11. 28.6mm rear sway bar made custom adjustable thanks to Scott Johnson
  12. 24mm H&R front bar
  13. Full Prothane bushing kit
  14. SPC camber caster strut mounts
  15. 17 x 7.5 ASA LW5 wheels
  16. 225/45-17 Dunlop SSRs
  17. Carbon fibre hood
  18. 8lb gel battery
  19. custom oil cooler
  20. custom 12.2 x 1.1" rotors with aluminum hats
  21. DIY conversion to Mustang Cobra front calipers
  22. bunch of other stuff I cannot recall
In process
  1. Convert rear toe links to spherical rod ends and aluminum adjustment tube
  2. Add Autometer shift light
  3. Switch to 225/45-17 Hoosier GAC tires
  4. Spherical bearing camber plates
  5. Homemade composite undertray
  6. Super secret front downforce project 8)
Next year
  1. SCT XCAL2 reflash to get rid of annoying check engine light from wholesale removal of emissions crap
  2. Safety equipment to do TT
  3. More roll stiffness - investigating use of circle track conventional springs front and newly available 3" ID coilover springs rear
  4. Seat time
  5. More seat time
  6. Nitrous :wink:
Rich
http://www.v8mongrel.com/
PostPosted: Thu Oct 13, 2005 4:23 pm
1994 Miata
Koni Yellows
Addco 7/8 front bar
Kuhmo Ecsta V710
plans: new front sway bar endlinks, sway bar brace hardware, and lots of seat time so it is tuned into time for Atlanta in February.
2010 Honda Fit Sport
Couple of bicycles
PostPosted: Thu Oct 13, 2005 4:27 pm
SUPER Post Whore
After this Friday... nothing other than driving. :)
- dow
PostPosted: Thu Oct 13, 2005 4:33 pm
88 bmw 535is:
Rebuild M30 B34 engine using B35 head (higher flow, bigger valves).
usual gamet of head work
bore out from 3.43L ish to ~3.62L
up compression to 9/9.5:1 from 8:1
MAF
lightweight flywheel
bigger injectors
upgraded cooling system
one piece aluminum driveshaft
paint job
looking for 300 crank hp
1-2 years or $5k later whichever comes first
TCD turbo kit..
15psi-ish
PostPosted: Thu Oct 13, 2005 4:39 pm
Borrowed '04 RX-8:
Mods:
1) Koni Singles
2) Kumho 710's
Plans:
1) Hope to force Mike Whitney to spend some money on his M3 :)
- AB
PostPosted: Thu Oct 13, 2005 4:43 pm
1985 Van Diemen RF-85 Formula Ford 1600. Has about 115 HP on a good day.
Runs in C Mod (when I take it out of its nice garage :D )
Anticipated Mods for 2006:
Fresh tires (Hoosier R25A slicks I assume) since the current set was first run on 9/11/2001 (seriously) at the Solo II Nationals.
Change Oil, check stuff, etc.
Wake up driver and take Geritol (aka Gene Miller . . . may he rest in peace :( )
See if I can beat SS, AP, DM, etc. cars for TTOD
:lol:
PostPosted: Thu Oct 13, 2005 5:01 pm
SUPER Post Whore
:lol:
You forgot STU ;)
- dow
PostPosted: Thu Oct 13, 2005 5:05 pm
^come on brian, lets hear whatcha got
PostPosted: Thu Oct 13, 2005 5:32 pm
I'm more of a simple pleasuRes type of dude, so if my car is running smoothly, getting me to and from work & autocrosses, I'm happy. I guess that's the beauty of running a stock class with a car that has decent shocks and brakes to start with. Don't get me wrong though, I'd love to have around 220 (all-motor) at the wheels. :twisted:
I do have a few plans:
-Saturday morning at 7am I'll be installing another Honda radiator and be $300 poorer
-Sunday afternoon, install a new clutch release cylinder because my clutch seems to want grab whenever the hell it wants to.
-Most importantly, during the off-season I'll be buying some Kumho R Compounds, but for the next few races I'll be chasing everyone in DS with some $59 Yokohama ES 100's. :oops:
