Diane Hall wrote:
OK, so we're getting our stuff together as far as building a place to stay for a long time. Part of the plan is a separate 4 car garage w/ lift (for all the toys). However, we're not sure how big to make it...
Whitney's is 24X40 IIRC, and I think he said he'd make it wider if he had it to do again.
Ron's is 30X60, which is probably bigger than we really need.
(Can a garage be too big?)
If anyone has seen any nice plans for garages, or has any suggestions on size I'd be glad to hear them. We're currently planning a 2x2 configuration on the parked cars (like Whitney's) with the 2 post lift in the "back" half. Buildable space shouldn't be a issue as the lot is 3 acres (and the house isn't that big), so any suggestions are appreciated.
Thanks!
If you (1) have lots of space, (2) have finite $$, (3) can and plan to build tall enough to have a full floored attic, and (4) plan to do 2x2, I think 30x44 would be great. 36' (what I have) is only good for 2 deep for short cars. 24' wide won't accomodate a car on a lift next to a parked car very easily.
However, if you can't go too tall and need to use vaulted trusses like I did, things get expensive past 24' wide unless you can have poles in the middle of the garage. For a tall, tall garage with a flat ceiling you can use LVLs to get over 24' wide. Again, $$
24x36 is fine for me ... as Joe points out it keeps my projects from multiplying. 30x44 or so is what I would have built if I had twice the land, money, and time, and if I wasn't worried about it looking too big.
One other dumb question -- how about 2 (or even 3) garages? One nice size for the daily drivers, and oone for the lifts and toys?
