DanDurusky wrote:
w/ the car off if you press and hold the brake pedal down it should press down a bit and then hold steady. pump it a few times and hold some more. does it hold hard or does it slowly sink down? thats the basic master cylinder check, it should hold steady and not sink at all.
up..
Pressing on the pedal as hard as I can, the pedal went half way to the floor. Pumping it 5 or 6 time did not change the distance it traveled. The pedal went half way to the floor and stayed there. Total pedal travel is 2 to 2 1/2 inches.
DanDurusky wrote:
how old is the brake fluid? air in the system will reduce teh transfer of pressure to the brakes.. lose enough pressure and the brakes wont lock up..
This is my track car so the fluid is changed often and the pedal pressure has alway been the same.
