Mike,
See Corner Carvers thread:
http://corner-carvers.com/forums/showthread.php?t=25105
We use one to heat our repair shop. We've had it about 15 yrs, and have been happy with the unit. I'm pretty sure it's a 180K btu Lenan. This past winter we did the first major maintenance it's required, replace the burner unit.
Major pro: Almost free heat, and plenty of it, IF you have a good source of used oil.
Minor cons: Doesn't like changes in the viscosity or temp of the feed oil. A change in either usually requires fine tuning the air volume and pressure to match the oil. The newer ones may be better in this respect, since we haven't had as much trouble with the new burner.
Doesn't like synthetic oils, since they have a different flash point than dino.
Doesn't like 90W gear oil unless you mix in some diesel to thin it down.
Most of our waste oil is 15-40 engine oil or 10w hydraulic, and it burns those without a hitch. We heat a 5K sf shop, and it keeps it 65 deg no problem. The heating season here is roughly Oct. thru March. During that time it will consume 1200-1500 gallons of waste oil, so you need a fairly substantial supply of oil. Other than the burner replacement, maintenance has been a yearly cleaning of the burner and nozzles, and fine tuning the air supply to match the oil being used. Be sure to place your used oil storage tank inside, since the temp changes if the oil is coming from outside storage really screw with the air requirements.
Overall it's been a real money saver and I'm pleased with it. A huge bonus is that the EPA considers a waste oil heater an acceptable method of waste oil disposal, and I don't have to pay a recycler to haul off my waste oil.
John
__________________
73 240Z w/355 chevy
