 Post subject: spark plug coil
PostPosted: Tue Jun 21, 2005 8:02 am
should i upgrade my coil over plug system? i have come across an aftermarket product that promises twice the secondary spark power. i have new plugs installed. 4 way Bosch, and they seem to have helped.
just wondering if i stand to gain anything more than a wallet lightening experience.
PostPosted: Tue Jun 21, 2005 8:05 am
Sponsored by Wal Mart!
By Bosch 4 ways, do you mean Bosch +4s?
Rich
http://www.v8mongrel.com/
PostPosted: Tue Jun 21, 2005 8:08 am
yes. 97 bmw 328is 6cyl.
PostPosted: Tue Jun 21, 2005 8:17 am
This is my opinion, not a fact, so take it for what it is worth (current market value is about a penny).
Most modern cars have a strong ignition system because misfires and incomplete combustion cause a spike in emissions. Upgrading to aftermarket ignition components will often make a difference simply because it is done when stock components are worn. Now, I know that some of the earlier BMW COP modules showed less than stellar reliability (~80K mile failures) and if the aftermarket performance units have done something to improve the reliability, then they might be worth a look. However, from a guaranteed +XXhp and +Ympg standpoint, I don't think they are a wise investment.
One way that you can assess the strength of your ignition system is by plug gap. A hotter ignition system is capable of jumping a larger gap. Running too small a gap can lead to incomplete ignition (spark blowout) and too large a gap misfire. So, the OEs typically have the gap right. Compare your car to others and see where you are. My Fords run an .050" gap.
Also, I have a big problem with Bosch +4's. They shroud the spark too much. A modern ignition system should have ZERO problems grounding to a conventional spark plug under almost all conditions. If the +4s made a big difference over a conventional electrode plug (I used Bosch Silvers in my BMW) then it might indicate that the ignition system is not that strong.
Of course, if you want to get into you can hook up and oscilloscope and do an ignition waveform analysis. :D
Rich
PostPosted: Tue Jun 21, 2005 8:32 am
thanks Rich. the car had +2's (not Bosch) with probably 25K miles on them when i swapped to +4's. the electrodes showed considerable wear.
as i only drove the car maybe 200 miles before changing the plugs, i can't say more than new plugs seem to run better.
