Charlie Smith wrote:
I think leaky master cylinders are a common problem with 3rd generation Integras. I replaced one on my GSR, on my brother's LS, and I think Jim Williams replaced his on his GSR. However, I didn't have to replace the slave on mine or my brother's car. I would recommend replacing the master cylinder only (and bleed the system) initially. If there are no more problems, I wouldn't worry about the slave.
The slave is fairly easy to access if you need to change it later. It is located on the front of the transaxle, near the exhaust manifold.
Does this mean your clutch is not broken?
Actually the clutch is indeed toast. I bled it and nothing changed. I'm 99% sure one of the springs on the disk went (again). I had the same problem on my '00 ITR.
I just dropped it off at the shop, but when I get it back I'll replace the master cylinder only for now. Seems fairly easy.
-Matt
p.s. My Hoosiers came in yesterday- YUMMY!
